Version 1.3 of the ArcGIS Maps SDK for Unity contains several highlights including enhanced support for virtual tabletops, the ability to modify the terrain and filter 3D features spatially, and improvements to the developer experience. This release continues our dual-purpose mission to bring accurate real-world geospatial data to Unity and to integrate GIS capabilities seamlessly with your game engine app development.
Virtual tabletops
Our Unity Maps SDK now provides first class support for building virtual tabletop experiences that enable users to visualize and interact with real-world geographic data in a scene placed on a surface within their virtual or physical environment. In most cases these immersive experiences are enabled through the use of extended reality (XR) headsets, such as Magic Leap 2, Meta Quest 2, and Varjo XR-3. These experiences are notably popular in the AEC, defense, and public safety sectors for collaborative planning scenarios where users can view, interact, and coordinate around a common, immersive digital operating picture and make informed decisions without the need to be in the same physical space.
Many of you started building virtual tabletop experiences using previous versions of the SDK and encountered some challenges. In response to your feedback, we have made several changes within the SDK to simplify handling the scale of a rendered tabletop and improve how changes to the observer position and geographic extent of the clipped area are calculated and propagated to ensure a smooth user experience. In addition to the underlying enhancements within the SDK, the plug-in contains a new tabletop sample for the Universal Render Pipeline (URP), for those of you targeting a broader range of devices, and the High Definition Render Pipeline (HDRP), for those targeting higher fidelity experiences on high-end hardware.
The sample contains an ArcGIS Tabletop Controller component that works with the ArcGIS Map and ArcGIS Camera components to determine the geospatial content to render plus a center location in real-world coordinates and a radius in real-world units to determine where and how far to clip the map. The sample also includes a new ArcGIS Tabletop Input Controller component that supports user navigation with the virtual tabletop. This sample is included with the downloadable plug-in and once imported can be found under Samples > Components.
![](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/08/UnityTabletopSample.jpg)
Mesh modifications
The foundation of your 3D maps in Unity will typically involve one or more elevation sources for the terrain and an integrated mesh scene layer that contains a continuous textured mesh representing real-world features, such as buildings and trees, and surface elevation information. Elevation sources and integrated mesh scene layers are typically generated by processing large sets of image data to create realistic 3D reconstructions of the world. In some scenarios you may want to modify or cutout an area of the terrain or integrated mesh and replace with other GIS content or game objects, without re-creating or editing the underlying data.
With the Unity Maps SDK you can now make on-the-fly modifications to your terrain and integrated mesh scene layers. When you add modifications, you are not changing the elevation surface or integrated mesh layer directly; rather, you’re modifying a representation of the data for an area of interest defined by a polygon. Mesh colliders will be updated ensuring that raycast operations honor your modifications. Clip modifications will remove content within the specified area, for example to expose underground utility lines at a construction site, and mask modifications retain only data within the specified area and remove everything outside, for example to only show a single city within a region.
With this release, you can define and apply mesh modifications using the C# API. Mesh modifications are not currently supported in the Map Creator UI or components. Also note in this release, mesh modifications are supported only on desktop platforms (Windows and macOS) while support on mobile platforms (Android and iOS) is on the roadmap for a future release. See the Mesh modification guide topic to find out more about modifying areas of integrated mesh scene layers and the elevation surface.
![](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/08/Unity_MM2.png)
Spatial Filtering
In many scenarios you want to represent real-world features, such as buildings, as true 3D objects that are explicitly modeled in three dimensions or perhaps you have 3D building information model (BIM) data representing both the exterior shell and all the interior components of buildings. Existing support in the Unity Maps SDK for both 3D object scene layers and building scene layers enables you to visualize and interact with this content. Complementing the new support for mesh modifications is the new ability to filter 3D scene layers by polygon areas enabling you to remove parts of 3D object scene layers and building scene layers after they are added to your map. Just as with mesh modifications, when you apply spatial filters, or cutouts, you are not changing the underlying data itself, only how it’s displayed and how it participates with mesh collisions such as raycasting. You can apply disjoint modifications that hide content from your 3D scene layers within the specified area, for example when you want to show another scene layer or game object representing a new building development, or you can apply a contains modification to include only content within a specified area.
In this release, you can define and apply spatial filters using the C# API. Spatial filters are not currently supported in the Map Creator UI or components. Also note in this release, spatial filtering is supported only on desktop platforms (Windows and macOS) while support on mobile platforms (Android and iOS) is on the roadmap for a future release. See the Spatial filtering guide topic to find out more about applying filters to 3D object and building scene layers.
![](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/08/Unity_SFF1.png)
Samples viewer
In response to your feedback, the samples viewer available from the GitHub repo has received a makeover and now has a beautiful, streamlined user interface, with many of the samples updated to follow the new style.
![](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/08/UnityMapsSDKSampleViewer.png)
Other enhancements
The samples included within the downloadable SDK plugin have also received a makeover and have been reorganized and updated as follows:
- When importing the samples, you’ll see these available as ‘Sample Content’ rather than ‘All Samples’.
- A new ‘Scenes’ folder includes samples for ‘HDRP’ and ‘URP’.
- Sample user interfaces updated.
Download and get started
To get the latest version go to the ArcGIS Developers site, sign in, and download the ArcGIS Maps SDK for Unity. See the Release Notes for more details about enhancements, deprecations, resolved issues, and known issues in this release. If you’re new to developing with our Unity Maps SDK, simply sign up for a free ArcGIS Developer account then head over to the Get Started page in the guide doc.
Article Discussion:
