There has been a lot of excitement around upcoming attribute rules’ functionality and Arcade expressions. In this blog, we will talk about attribute rules, a little bit of history on the ideas behind its development, and new features that are coming soon.
In this blog, we will talk about the history and development of attribute rules as well as review new features.
A brief history of improving data quality in ArcGIS
Over the years, a lot of endeavors were undertaken to improve the data quality of the GIS system. Geodatabase domains helped reduce erroneous entries through picklist instead of free typing. Default values on fields simplified the editing process. With subtypes, a field can have a different default value and domain based on which subtype the feature belongs to. Editing templates drastically simplified the editing experience, allowing users to pick a pre-defined editing template and create a feature with predefined attributes. Group and pre-set templates helped bring together multiple templates allowing users to create multiple features with one click.
With Attribute Assistant and Data Reviewer, users were able to create rules to auto-populate attributes and create errors for invalid entries. This allowed users to be much more productive by employing parameters to improve the quality of the data. However, Data Reviewer and Attribute Assistant functionalities are only enforced while editing through the application (in ArcMap and ArcGIS Pro). Edits that came through other applications such as web or mobile apps like ArcGIS Collector have the potential to avoid proper validation; creating a situation where bad quality data can still make it into the geodatabase.
Esri decided to push the evaluation logic deep down at the lowest level where all client edits eventually end up; within the geodatabase. This resulted in the evolution of attribute rules. Attribute rules are scripts that a user can define on datasets. They trigger automatically with incoming edits and can be used to constrain the attribute values allowed on fields or perform a calculation to derive a field’s value. They can also be run on-demand to calculate values and also create errors for features that violate any rules (new at ArcGIS Pro 2.3/ArcGIS Enterprise 10.7). This can be done after editing or perhaps as a nightly job.
Attribute rules are designed to run on the entire ArcGIS ecosystem. This is possible with the new Arcade scripting language which provides a richer and more extensible experience of the Esri GIS platform. Arcade enables enhanced labeling, popups, defined symbol sets, display settings, and now, improved attribute rules. Arcade runs on any environment, desktop, server, web, mobile, and much more. It is continuously evolving as a scripting language. Learn more about Arcade here.
Here some examples of attribute rules.
What’s new for Attribute Rules
In ArcGIS Pro 2.2, users can create attribute rules that fire on edit events such as insert, update or delete operations. These rules are referred to as immediate rules which are either constraint or calculation. Constraint rules can block the edit if the rule’s script is evaluated to false. Calculation rules can evaluate its script and persist the result in an attribute on an edited feature. These rules are only limited to the edited feature; i.e. users cannot access features from other layers or even other features from the same layer.
The ArcGIS Pro 2.3 and ArcGIS Enterprise 10.7 release includes the following enhancement to attribute rules:
- New Arcade functionality
- New rule types
- Improved user experience.
In ArcGIS Pro 2.3, the Arcade language is expanded to include a FeatureSet type which allows attribute rules to access other features. This approach unlocks the potential for creating various rules, such as ‘don’t create parcels that intersect other parcels’; ‘auto-populate the project attribute from its nearest feature’; or ‘calculate the rotation angle of a valve based on the pipe it is created for’.
New rule types and Validation server capability
In ArcGIS Pro 2.3/ArcGIS Enterprise 10.7, batch calculation and validation attribute rule types are added. These rule types are evaluated via feature services that include the Validation capability. The Validation capability can be enabled on a feature service starting at ArcGIS Enterprise 10.7. This will enable evaluation of batch calculation rules and validation rules on the server. As you might imagine, this functionality is a longer topic, so I will write a follow-up blog with greater detail.
Note: Creating Batch attribute rules (validation and batch calculation) will add the ValidationStatus field that will be used to track the state of the feature. Batch rules are only available for server-side evaluation with ArcGIS Enterprise 10.7 and cannot be published or evaluated on earlier releases.
Validation Rules
Validation attribute rules can be created and evaluated on demand to create errors for features that violate the rule. An example of a validation rule could be to create an error if the number of wires contained within a duct exceeded the maximum wires capacity of the duct.
Batch Calculation Rules
Calculation rules can also be run on batch mode at a user-defined time. Users who have authored compute-intensive scripts that don’t necessarily scale when running in immediate mode can specifically take advantage of the batch mode. Having these rules fire on demand asynchronously on the server can offload and increase the throughput of editing. Batch rules (especially validation rules) can evaluate and create errors for those features that do not satisfy the user rule. So instead of preventing the user from entering bad data, users can make the edits, and a batch process will execute all rules and flag all offending features as errors.
An example of a batch calculation rule could be calculating the total kVA in a substation by summing all containing transformers.
There are trade-offs to be considered when choosing between immediate and batch rules. Immediate attribute rules improve the quality of the data as users make edits by preventing bad data from being entered, but you must consider the throughput resulting from the compute cost of the rules. More complex rules will logically have a higher compute cost. Batch attribute rules won’t have an immediate effect on editing performance but will allow any data to go in. At a later time, the evaluation process will flag ‘bad’ features as errors. When that occurs, another workflow can be used to resolve those errors.
Improved User Experience
With ArcGIS Pro 2.3 we have enhanced the user experience for authoring attribute rules. Users can view properties for existing rules and author attribute rules more intuitively. The error inspector is also redesigned to support evaluating attribute rules and displaying validation errors.
The Attribute Rules view and ribbon are available in ArcGIS Pro 2.3 to work with existing rules for a dataset and to author attribute rules.
What’s Next for Attribute Rules?
We are not done yet! This project is exciting with a lot of things coming beyond 2.3 and 10.7; here are some of the items we are working on for the coming releases.
Support attribute rules on file geodatabases – We will provide support for adding and executing immediate attribute rules (calculation and constraint) on file geodatabases.
Prevent posting errors marked as ‘Severe’ – Another upcoming option is the ability to tag errors with severity (1-5 scale) to prevent users ever posting to DEFAULT any features that have a severity of 1.
New evaluation types – The validation server for 10.7 supports evaluating Calculation and Validation rules. In future releases, we will augment the server to evaluate many other geodatabase elements such as domains, contingent values, subtypes and relationships.
Is a csv version of the table data available for the public, and if so, where?
Check the notes on the JHU Dashboard page for current information on this topic.
See the Johns Hopkins Dashboard
Yes, see the links in the first paragraph. Several will lead you to the JHU sources available for download.
Jim, thank you very much!!! This is fantastic!! BRAVO!
So helpful, thank you!
Here is a sample web map that utilizes the County level data for the US at the right scales, and shows counts of Active cases outside the US where that data is available. The popups use Arcade to determine the right information to show for locations around the world and in the U.S.
This is huge, thank you!!
Thank You Esri and Johns Hopkins University! We have it in our Operations Dashboard for Audubon https://audubon.maps.arcgis.com/apps/opsdashboard/index.html#/e43d484191614f3fa1ace1c5e64d273b
Hey Jim Herries!
Good work.
can you please inform me that , the data Is it available publicly or not. Kindly inform
Thank you so much for your time
Yes, it is available publicly. See any of the links in the article above.
Hello Jim, Thank you for sharing this. It is really helpful. We are using this map layer using our Power BI ArcGis Plugin. I just noticed and wanted to bring to your attention that this map layer is showing a red dot on lot of counties even there is no confirmed, death or active cases. For example if you search for Mason, TX, USA (Mason County) and zoom out from the link below, you will see a red dot for this county even there is no Covid-19 activity. I think this is what we are using in our Power BI… Read more »
Thanks for pointing that out. I see it has been fixed now in the layer, where a filter “Confirmed > 0” is now applied. A MIN value in the legend of 1 would have had the same effect as a filter. A MAX value that is too small may cause features to suddenly stop drawing if the # of cases exceeds whatever you save as your MAX value. So think ahead to a worst case scenario and set your MAX value to that, to future-proof your classifications. If you turn off classification, you won’t have to worry about the MAX… Read more »
Hi Jim! What is the best way to get the total for the US? Adding up the states seems to be off. Thanks!
Use this layer for the Countries total.
Hi Jim, We are looking for a layer that is dynamically updated with State Closure information. I’ve looked through the living atlas and haven’t found anything. Have you seen an AGOL layer such as that?
Many thanks and keep up the good work,
Ron Salz
Chief Cartographer
National Wildlife Refuge System
I have not, but here’s a useful search pattern where you specify what you want in the title, and add other words to contextualize the search: title:closure covid
Just saw this today: https://arc-nhq-gis.maps.arcgis.com/apps/webappviewer/index.html?id=ebe29d4c1fca4ac292d00dbd54ed37e9
Morning Jim,
Am I correct in saying that the counties of the Bronx, Queens and Kings are still missing from the following rest service ?
https://services1.arcgis.com/0MSEUqKaxRlEPj5g/arcgis/rest/services/ncov_cases_US/FeatureServer/0
This is the fourth time I’ve posted on a blog. But still no clarification.
Regards.
Jeremy.
Jeremy, I checked the layer and there is data for a feature named “New York City” which represents the 5 boroughs. To see it, open the layer, hit “Change style” and set the max value to something like 1,000,000 so that the feature draws. Right now, NYC has 210,000+ total cases, but the classification has a max value of 100,000 so the feature doesn’t draw. I’ve let the team know about this, so it should get corrected in the layer, but you don’t have to wait for that if you’ve put the layer into a web map or other app… Read more »
