ArcGIS Blog
Analytics
ArcGIS Pro
Track Heat Mapping with GeoAnalytics Desktop tools
By Bethany Scott
Quite often analysts are tasked with uncovering the patterns of where objects travel. For example, this could be showing patterns in vehicle movement, animal behavior, or sensor data. This blog outlines a simple workflow using GeoAnalytics Desktop tools to create a track heat map in three quick steps: create lines of movement from GPS points, aggregate lines into bins, and symbolize your results.
Unsure whether you have track data? Tracks are points collected over time with a unique identifier for each object being observed. Examples of a unique identifier are the FlightIDs for airplanes or the name of a hurricane.
GIF depicting an example of a track dataset
In this workflow we analyze tracks composed of 50 million GPS points representing ship movement near Hawaii. Each GPS point has a field for the time, location, and a ship ID as well as some other attributes like status, heading, and vessel type. Using ArcGIS Pro, let’s visualize the input tracks as they travel near Hawaii:
50 million GPS locations of AIS ship data
50 million GPS locations of AIS ship data used as input for analysis
As you can see, other than noting that ships aren’t traveling on land, there aren’t many noticeable patterns. To uncover patterns in a large dataset like this, it’s common to aggregate all the raw points into bins (squares or hexagons) to show where the most observations were made. However, binning the points won’t reveal the travel patterns of sequential points (tracks); instead it will just analyze where the GPS points were collected. Because we’re interested in the pathways of ships, let’s use a more suitable workflow for track analysis than point binning.
Step 1: Create tracks from time-enabled points
To create the track features (lines) we want to visualize as a heat map, use the GeoAnalytics tool Reconstruct Tracks. This powerful tool summarizes points collected over time into lines representing unique track events for each object.
Reconstruct Tracks result
Example result of Reconstruct Tracks using GeoAnalytics Desktop tools
For this workflow, we use the field VesselName to identify unique ships. Additionally, we choose to split tracks when there’s a time lapse of 6 Hours or more between points. For example, here are the input parameters:
Parameters used in heat map analysis for the Reconstruct Tracks GeoAnalytics Desktop tool
The result contains trips (blue lines in the map below) for each vessel.
Reconstruct Tracks result showing individual trips for each tracked vessel
Step 2: Aggregate track features into hexagon bins
Next, we create the heat map of the tracks. Since we’re interested in a detailed heat map, we use a grid distance of 1 mile. We use the GeoAnalytics Desktop tool Summarize Within – which can summarize points, lines or polygons into polygons or bins. Here is an example of the input parameters:
Summarize Within GeoAnalytics Desktop tool parameters
Parameters used in heat map analysis for the Summarize Within GeoAnalytics Desktop tool
Step 3: Symbolize your results
The result of Summarize Within is a hexagonal grid with a COUNT field to tell us how many ships traveled through each grid cell. To symbolize the result as a heat map and make the high-count locations standout, use Unclassed Colors and a Multipart Color Scheme on the COUNT field. Here is what the symbology parameters look like:
Parameters used for symbolizing a heat map
Heat map symbology applied to the Summarize Within result
The output of the Summarize Within tool is a heat map representation of trends within your track dataset. Contrast the results of Reconstruct Tracks (blue lines) and Summarize Within (heat map) to visualize the impact this heat map workflow has in understanding track patterns. The heat map uncovers trends in ship traffic volume that would have otherwise been hidden without summarizing the large datasets using GeoAnalytics. We use the Swipe effect tool in ArcGIS Pro to really illustrate the improvements:
Heat map compared with individual tracks using the Swipe effect in ArcGIS Pro
Remember how this workflow begins with 50 million points? Well, on my laptop I was able to run Reconstruct Tracks analysis in just under 5 minutes and Summarize Within in only 2 minutes! GeoAnalytics Desktop tools allow us to complete jobs that may have previously (before parallel analysis with GeoAnalytics) not completed or took multiple hours using analysis tools.
Are you currently working with track datasets? Comment below and tell us about the problems you are solving and the workflows you use to do it.
If you’re interested in completing this workflow, check out a sample script (and sample data) written in arcpy here.
Laptop specs : 16 GB of RAM, 4 cores.
Share this article
Subscribe
Notify of
5 Comments
Oldest
Newest
Inline Feedbacks
View all comments
Scott Troppy(@epiland98)
February 24, 2020 5:10 pm
The link above does not work for me – not part of the group. Is there a way to have access? Thanks.
It works now – will give it a try.
Amilynn Adams(@sempergumby)
July 6, 2020 8:26 am
@bethanyscott-2-2 – I need to pick your brain! I work exclusively with AIS data, in various stages of processing (good, bad, and ugly) and am currently trying to figure out how to clean up some previously joined AIS point data…additionally, my “summarize within” tool doesn’t appear to have the same fields as the one shown in your article.
August 13, 2020 1:19 pm
Reply to  Bethany Scott
OK…well, I’ve made some progress since I last posted. I was put in touch with Keith VanGraafeiland and we discussed the questions you’ve posed. Trying to clean up our data has him a little stumped too (which makes me feel better about my level of GIS competence), but we’ve got a follow-on meeting with him this coming Monday where hopefully he’ll be able to reveal a solution. We still have work to do in terms of data quality and preparation (ESRI calls this step “data engineering” right?) though, so the referral to that group email is MUCH APPRECIATED. As for… Read more »
