ArcGIS Blog
3D Visualization & Analytics
ArcGIS Pro
What's new with Mobile Scene Packages (ArcGIS Pro 2.5)
By Andrew Johnson
   Mobile scene packages were introduced back in ArcGIS Pro 2.3. Support for mobile scene packages has expanded across the ArcGIS Platform. You can package your 3D content and scenes and consume them offline in popular ArcGIS Runtime clients such as ArcGIS Earth, ArcGIS Earth mobile, and Appstudio for ArcGIS. You can also build custom ArcGIS Runtime apps to consume these packages. At ArcGIS Pro 2.5 we are excited to announce additional functionality that will not only make it easier to create mobile scene packages but support functionality you have requested.
Rasters as elevation sources
    In the first releases of mobile scene packages, tile packages were the only allowed elevation sources in mobile scene packages. ArcGIS Pro 2.5 supports writing non-tiled raster files as elevation sources to mobile scene packages.  Reading non-tiled raster files as elevation sources from mobile scene packages will be supported in ArcGIS Runtime 100.7. Keep in mind that not all Esri clients such as ArcGIS Earth will be on the 100.7 Runtime immediately.
Transportation Networks
    Transportation networks are now supported in mobile scene packages. If you have a network dataset in your scene it will now be packaged as a transportation network in the mobile scene package for 3D routing workflows in ArcGIS Runtime apps.
Services
    Until now mobile scene packages have been an offline-only capability. In order to accommodate offline and online workflows ArcGIS Pro 2.5 will allow certain services to be written to the mobile scene package. These include map, scene and image services. An important note here is that services in mobile scene packages are not currently supported in ArcGIS Runtime clients but support is expected later this year. Until this feature is supported in ArcGIS Runtime, please continue to use local datasets only when working with ArcGIS Earth or other ArcGIS Runtime based apps.
Related Records
    A new parameter  Select Related Rows has been added to the create mobile scene package tool to allow clipping of features with related records. This matches functionality that is seen in the create mobile map package tool and will reduce the size of packages when using an extent or area of interest parameter.
Additional Mobile Scene Package Resources
    Please continue to post requested functionality on ArcGIS Ideas. Also post to Geonet or reach out to Technical Support for any questions or concerns.
Free ArcGIS Pro Trial
Share this article
