There is an exciting and new 2020 European Space Agency layer in ArcGIS Living Atlas that classifies the earth into 10 land cover types at a scale of 10-meters. The resolution is incredible, and we’ve written this blog, if you are interested in finding out more. Today, I am writing about one of the 10 classes included in that layer: Mangrove Ecosystems.
By separating out mangroves into their own land use designation, you can find them easily and also see them in their entirety all over the earth.
![ESA landcover map showing Phuket, Krabi, and Surat Thani. ESA landcover map showing Phuket, Krabi, and Surat Thani.](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/04/PhuketKrabiMangroves-01-scaled.jpg)
Special Ecosystems
Mangrove ecosystems are unique. They are composed of salt tolerant trees and shrubs with complex root systems and are found in tropical and subtropical latitudes from 25° North to 25° South. Incredibly, each year mangroves and coastal wetlands sequester carbon at a rate ten times greater than older well established tropical forests. They also provide benefits like protecting water quality by filtering out pollutants before they reach seagrass habitats and coral reefs. They act as a natural buffer by stabilizing the coastline and prevent erosion during storm surges and heavy rains. Mangroves provide a safe nursery habitat for fish, shelter terrestrial wildlife species, and act as a secure nesting and seasonal migration habitat for coastal birds. They are especially important ecosystems on our planet.
![Mangrove forest at Phang Nga Bay in Thailand. Mangrove forest at Phang Nga Bay in Thailand.](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/04/MangrovesPhangNgaBayThailand-scaled.jpg)
Only 42% of mangrove habitats are found within designated protected areas and they are under threat. Human related activities such as farmland conversion, aquaculture, and urbanization have led to a 60% loss of habitat. The effects of climate change are further impacting them through storm surges, sea level rise, and erosion.
Having this 2020 global resource available at 10-meter resolution in the Living Atlas library allows anyone to take a closer look at these fragile and important ecosystems. You can add this layer directly into ArcGIS Pro and run zonal or summary statistics or leverage the many options available with geoenrichment to better understand the human related impacts and what is driving them.
Mangrove Mapping
Objective: Find out where mangroves are globally and highlight them. This kind of map should be minimal in its composition and the focus should be on mangrove ecosystems in the context of where land meets the sea. A dark basemap is perfect to focus our attention and all it took was a few clicks to blend Firefly and Human Geography Dark basemaps together, plus some of the awesome ArcGIS layer effects for this map to come together.
The basemap is broken into two parts. The ‘background’ basemap is Human Geography Dark Detail and Label and Firefly. Here is how they set up:
![Animated gif showing how the first part of the basemap is set up. Animated gif showing how the first part of the basemap is set up.](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/04/Basemap1.gif)
The second portion of the ‘basemap’ is within the actual map layers. World Countries was used so that the land is the darkest thing on the page and disappears. Then Human Geography Dark Base helps to mask out the ocean using the blend mode ‘Hard Light’, so its color is multiplied by the background’s color. Since they both are dark it creates these cool shadows.
![Animated gif showing how the second part of the basemap is set up. Animated gif showing how the second part of the basemap is set up.](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/04/MangroveBase2.gif)
Next add in the 2020 European Space Agency layer. To only show just the mangroves, since this is a tiled imagery service, you are unable to leverage a definition query. So, to isolate just the mangrove land cover class, turn off all the other land use classes one by one.
![Animated gif showing how to turn off all of the ESA land cover classes to just show the mangrove class. Animated gif showing how to turn off all of the ESA land cover classes to just show the mangrove class.](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/04/TurnOffLC.gif)
Just mangroves now.
![Map showing just the mangroves class. Map showing just the mangroves class.](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/04/JustMangroves.jpg)
Let’s pump up the color so it is a bit brighter like #00ffb7 which is just on the edge of green and blue. Like mangroves – green plants and blue water.
![Where to change the color on the land cover layer in ArcGIS Online. Where to change the color on the land cover layer in ArcGIS Online.](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/04/MangrovesPumpupColor.jpg)
Now let us make them pop with Layer Effects. First zoom in.
![Zoomed in map of Thailand and the mangroves. Zoomed in map of Thailand and the mangroves.](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/04/MangroveZoomIn.jpg)
I am going to apply Bloom first which gives it that beautiful glow like bioluminescence in the ocean by the moon at night.
![Use the Bloom layer effect on the mangroves. Use the Bloom layer effect on the mangroves.](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/04/MangroveBloom.jpg)
Next, I’ll add a Drop Shadow and pick a color like #0ff5a8 which will compliment my other color and set the opacity to 60% so its super dreamy looking.
![Use the Drop Shadow layer effect on the mangroves. Use the Drop Shadow layer effect on the mangroves.](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/04/MangroveBloom_DropShadow.jpg)
That’s it! Let us check out a couple of spots around the globe!
Southeast Asia contains nearly a third of the world’s mangroves. Indonesia alone houses 20% of the global total! Unfortunately, some of the largest mangrove habitat losses are found in East and North Kalimantan, Riau, and West Papua in Indonesia; the Mekong Delta in Vietnam; and the Irrawaddy Delta in Myanmar.
![Map showing mangroves in Southeast Asia. Map showing mangroves in Southeast Asia.](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/04/MangrovesSEAsia.jpg)
The Cross River Estuary in Nigeria is the biggest mangrove ecosystem in Africa. Local deforestation and encroachment from fishing communities has put significant pressure on these sensitive forests.
![Map showing mangroves in West Africa. Map showing mangroves in West Africa.](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/04/MangrovesNigeria.jpg)
The mangroves found in the Persian Gulf and Strait of Hormuz provide clean air and recreation opportunities for dwellers of big cities like Abu Dhabi and Dubai. The mangroves in these areas are also highly adapted to extreme salinity and temperature variability.
![Map showing mangroves in the Persian Gulf and Strait of Hormuz. Map showing mangroves in the Persian Gulf and Strait of Hormuz.](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/04/MangrovesUAE.jpg)
There still is hope for mangrove protection and restoration. In 2021, Costa Rica announced that it was going to restore and protect 22,000 hectares of their remaining mangroves. Belize committed to protecting 6,000 hectares by 2025 and another 6,000 by 2030, doubling their current levels of protection. This year Cuba established a new 72,778 hectare marine protected area covering mangrove forests, seagrass beds and coral reefs.
![Map showing mangroves in Central America and the Caribbean Sea. Map showing mangroves in Central America and the Caribbean Sea.](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/04/MangrovesCentralAmerica.jpg)
The only thing better than exploring this incredible 10-meter layer in ArcGIS is seeing these mangroves up close and in person. There are so many mangrove spots to visit. Time to plan a trip!
![Map showing the extent of mangroves globally. Map showing the extent of mangroves globally.](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/04/MangrovesGlobal.jpg)
Please find the web map that created these maps here.
For more information about Layer Effects and Blend Modes here are a few additional resources:
Map Viewer Effects: Drop Shadow and Population Footprint
Five Minutes with Layer Effects
One Minute Map Hack: Turn Any ArcGIS Online Map Into Firefly, With the Bloom Effect
Blend Modes for Thematic Maps
Blend Modes are here and they’re pretty awesome
How to Make Your ArcGIS Pro Map Awesome with One Blend Mode
Also be sure to check out the blogs listed below. Feel free to reach out to me with comments or questions. Thank you!
Article Discussion:
