Did you know that you can add demographics to your existing geographical datasets? Whether you have points, tables, lines, or polygons, demographic data can add value to your analyses. The blog, “Make a Demographic Map in 5 Minutes”, introduced the basics for using the Enrich Layer tool in ArcGIS Online, and introduced the interface of the Data Browser. Now, we will see additional ways this technique can be applied, using the same underlying process, and still only taking minutes to complete. Each method produces a new layer within your “My Content” which can be used throughout the ArcGIS platform. To get started, publish your layer to ArcGIS Online using your organizational account.
Points
Scenario: You have point data for hospitals in your area. You need to know how many low-income households are within a 5-minute drive for each of these hospitals.
- Analysis >> Data Enrichment >> Enrich Layer >> Choose your point layer
- Select Variables (try searching for ‘poverty’ to find variables related to low-income households. The ACS (American Community Survey) calculates poverty thresholds based on size of family and number of children)
- Define an area to enrich. The options are:
For this scenario, Drive time >> 5 minutes >> Choose “Return result as bounding area”
- Choose a layer name and folder >>> Run Analysis
- A new layer will appear with demographics added to your existing data
- Select the variable(s) you want to explore within the “Change Style” option
Tip: If you are looking for hospital points in the US, there is a map available in the Living Atlas of the World
Lines
Scenario: You have linear data for the LA Marathon route. You need to know how many retail businesses are within a mile of that route so that you can assess the impact of this event.
- Analysis >> Data Enrichment >> Enrich Layer >> Choose your marathon route
- Select Variables (the “Business” Data Collection is full of variables about businesses, employees, and sales for different NAICS/SIC codes)
- Define the area you want to enrich (starting to see a pattern?)
- Select the variable you want to explore within the “Change Style” option
Excel/CSV
Scenario: You have a table of possible locations for a new grocery store. You need to know information about the income of the people living near these addresses so that you can select an ideal location.
- Convert your table to csv format if it is not already. It needs to include a field with geographic reference in order to be added to the map.
- Drag/drop your csv file straight into the map within ArcGIS Online. The locations will be geocoded onto the map based on your geographic field.
- Analysis >> Data Enrichment >> select the point layer you just created
- Select Variables (check out the “Income” Data Collection)
- Define the area to enrich around your location
Tip: you can also do this in Maps for Office and share your layer to ArcGIS Online
Polygons (this was covered in the previous blog, but let’s take a quick look at the process again)
Scenario: You have a boundary of your company’s service area, and you need to know how many people live in the area, and how much growth will happen in the next 5 years
- Analysis >> Data Enrichment >> select your polygon layer as the input
- Select Variables (There are 5-year estimates for some variables, such as population)
Tip: Need your data in ArcMap? Once you enrich your data layer, you can open it in ArcMap using different data formats!
Very cool.
Is support for Azure Data Warehouse on the roadmap?
Support for Azure Synapse Analytics (Azure SQL Data Warehouse) is being planned for a future release. I’ll touch base with you to learn more about the various data sets you currently have in this data store that supports your use-cases, and how you would like to interact with it within ArcGIS to meet your goals.
Thanks Nana.
It would be great to be able to access our Synapse data the same way as what’s described in this article:
https://www.esri.com/arcgis-blog/products/arcgis-enterprise/data-management/new-in-arcgis-enterprise-10-9-1-cloud-data-warehouse-support
We’re interested in being informed as well
Our company in the design phase for an spatial enterprise data warehouse, and have chosen Azure as our cloud provider as well. Trying to determine whether Synapse can interface with a PostgreSQL database where our spatial data is to reside, but if Pro/GIS Services can hit Synapse directly, we would be WAY better off.
