ArcGIS Blog
Mapping
ArcGIS Configurable Apps
Enhance Attachment Viewer Capabilities with Full Setup
By Krista McPherson
Attachment Viewer is a configurable app (introduced with the June 2019 update of ArcGIS Online) that allows you to work with images and features on a map. You can build an app that presents spatial data with an intuitive feature-by-feature browsing experience while viewing images stored as attachments. App users can browse through each feature and view the pop-up information and attached images. Whether working with pre-existing images or incorporating them during data collection, you can use Attachment Viewer for datasets with images, videos, or PDF attachments. You can pair it with data collection workflows using Esri apps such as Geoform, Survey123, Web AppBuilder, ArcGIS Collector, and QuickCapture.
This blog post will discuss options that are available in Full Setup, which allows access to all settings supported by the app and extends the capabilities of the Express Setup, which are detailed in Build an Attachment Viewer App with Express Setup. Full Setup is a part of the updated configuration experience available with JavaScript 4.x configurable apps.
Switch from Express to Full Setup
By default, the app opens in Express Setup, which contains the most essential settings for configuring the app. To switch to the Full Setup experience, click on the Switch to Full Setup button on the left hand Action Bar (Image 1).
Image of workflow to switch to full setup experience
Image 1 - Switch to Full Setup
Once in the Full Setup experience, the configuration panel lists the same four categories of settings available in Express: Map, About, Interactivity, and Theme & Layout. Clicking each section reveals more settings for each category (Image 2).
Image of the settings available in the Interactivity section of Full Setup
Image 2 - Interactivity section of Full Setup experience
Show Image Direction
Image Direction is in the About section under Location Details. If images in your attachments contain exif data, enabling this setting displays the GPS image direction in the lower left corner of the attachment window (Image 3). This information provides app users with information about how and where the image was captured.
Image of photo in Attachment Viewer application with Image Direction information displayed
Image 3 - Photo displayed in Attachment Viewer with Image Direction enabled
Feature Selection
To allow your app users to select a subset of features on the map, you can enable the Feature Selection tool (Image 5) in Interactivity under the Modify subsection. This tool allows app users to draw a selection box around a cluster of features and browse through the attachments associated with the features selected. When a group of features is selected on the map, only the attachments associated with the selected features appear in the attachment pane.
Image of a web map with the feature selection tool enabled and a set of features selected
Image 5 - A group of selected features on the map with only associated attachments visible
Image Downloads
To allow users to download your attachments, enable image downloads in Interactivity under the Share section. Once this setting is enabled, a download button appears at the lower right corner of the image attachment (Image 6), which users can click to download attached files. This option is compatible with attached video files as well as image attachments.
Image of an Attachment Viewer application with image downloads enabled, highlighting download button
Image 6 - Attachment Viewer app with image downloads enabled
Share the App
Once you are finished configuring the app, the app is ready to be published and shared with your audience. Browse to the bottom of the configuration panel and click Publish to open the Publish window (Image 7).
Image of the Publish button and Confirm Publish button for configurable apps
Image 7 - Publish the app to save settings and share the app
Click Confirm to save all settings and publish the app. The app is now ready to be shared. Share your work on GeoNet to show others what you can do with Attachment Viewer.
Share this article
Subscribe
Notify of
4 Comments
Oldest
Newest
Inline Feedbacks
View all comments
Saadullah Baloch(@sbaloch_bcgis)
November 3, 2023 4:59 am
This last picture looks like solving a puzzle for Minesweeper.
