We are pleased to announce the release of ArcGIS Maps for Office v4.1.
ArcGIS Maps for Office 4.1 is a minor update that brings you improved speed, better usability, and many bug fixes. Here are some highlights:
- ArcGIS Maps for Office now recognizes your organization’s default geocoder.
- ArcGIS Maps for Office now uses a Chromium-based browser to display maps, meaning that working with your data is much quicker. Even when working with lots of data, you can pan and zoom your maps effortlessly.
- ArcGIS Maps for Office now supports vector basemaps and layers, which means your maps look even better on high-resolution monitors.
- You can now select items on a map and export the corresponding rows of data to a new worksheet or new Excel workbook, allowing you to work with the data where you want.
- Visual improvements to the Add Data and Style Layer interfaces help you load and visualize your data more easily.
- Pop-up infographic settings persist across layers, so you don’t have to make changes to each individual layer.
- Cells that contain formulas update the map when the source data is updated.
- Map and layer styles are rendered correctly when cell values change.
- You can now specify the spatial reference system to use when you export a layer.
- Many more bug fixes, including localization and internationalization issues
For information about installing and using the product, see the ArcGIS Maps for Office web help and be sure to visit GeoNet to get help from the community.
~The ArcGIS Maps for Office team
Article Discussion:
