![]() Clip a raster to any shape you create using ArcMap software's drawing tools. | |
![]() In the Export Raster Data dialog box, set parameters such as cell size, output file format, and spatial reference. |
English / Spanish
Make raster datasets more manageable by clipping rasters in ArcMap using a graphic you draw as a template. Draw any graphic shape and use that shape to clip out just the extent you want. Export this clipped raster as a BMP, GIF, GRID, IMAGINE, JPEG, JPEG 2000, PNG, or TIFF file. This functionality is very useful for quickly and easily defining a study area.
If desired, check the Force RGB box to export the output raster as a three-band RGB raster dataset with the current renderer and specify a NoData value for the output. The default cell size is the dataset's original cell size.
Browse to the location to save the exported raster dataset, name it, and use a raster format. If the output location is a geodatabase, the output type will automatically be the correct geodatabase type.
