Menu
News
ArcUser
Search ArcUser
Fall 2012 Edition
An Integrated Land Records Solution
This article as a PDF.
Land records provide the foundation for local government GIS. Not only are parcel records used for assigning landownership, managing valuations of land and associated improvements, and applying land-use and zoning designations, but they also act as a basemap for overlaying feature classes, such as building polygons or utility lines, which are constructed in relation to parcel boundaries. Thus parcel layers provide the framework for other GIS applications that maintain public infrastructure, encourage economic development, and optimize emergency response.
ArcGIS 10 introduces a comprehensive solution for land records creation and maintenance that consists of three key components: the parcel data model or parcel fabric, the Parcel Editor toolbar, and the Tax Parcel Editing template. This systematic approach uses topology to enforce data integrity, streamlines daily maintenance tasks, and can improve positional accuracy over time.
The parcel fabric is a map layer depicting land division that stores a continuous surface of connected parcels, or a parcel network. The parcel fabric dataset is a set of related feature classes, tables, and relationships in a geodatabase that supports the management, analysis, and mapping of land parcels. A parcel-based topology stores each parcel's boundary lines and the common corners shared by neighboring parcels.
There are many reasons to migrate parcel data currently maintained outside the parcel fabric in feature classes, coverages, or CAD layers:
The other two components of land records maintenance in ArcGIS are the Parcel Editor toolbar and the Tax Parcel Editing template. Available with ArcGIS for Desktop at the Standard and Advanced license levels, the Parcel Editor toolbar contains tools for performing splits, combines, and other common operations on parcel data using a streamlined set of workflows. The Tax Parcel Editing template provides a multiscale editing map that organizes the survey framework (Public Land Survey System and control), subdivisions, lots, tax parcels, and encumbrances in the parcel fabric data model that can be used with the Parcel Editor toolbar.
The parcel data model, additional parcel editing tools, and Tax Parcel Editing template can be downloaded from the Land Records section of the ArcGIS for Local Government resource center.
Components of the parcel fabric dataset
ComponentTypeFunction
Parcel lines Feature class Store and preserve recorded boundary dimensions
Parcel points Feature class Store x,y,z coordinates derived from a least-squares adjustment
Parcel polygons Feature class Are defined by parcel lines
Line points Feature class Are parcel corner points that lie on the boundaries of adjacent parcels
Control points Feature class Contain the accurate, published coordinates for a physical location
Plans Table Store information about the record of survey
Parcel fabric jobs Table Track edits to the parcel fabric
Accuracies Table Weight parcels in the least-squares adjustment
Adjustment vectors Table Store sets of displacement vectors from least-squares adjustments
