ArcView GIS 3.2 Now Available
An enhanced CADReader extension to support AutoCAD 2000 (Release 15) drawing files will also be available to ArcView GIS 3.2 users as soon as possible for no additional charge. ArcView GIS Projection Utility
Database Access Version 2.0Database Access Version 2.0 has been enhanced to provide a unified access interface to ODBC-compliant databases as well as SDE databases. ODBC Database Access--Database Access Version 2.0 supports connecting to any ODBC-compliant database. Once connected to an ODBC database, the user can create database tables or initiate scripts that perform actions on the data in the database. Database Access provides a consistent and robust wizard-driven interface alternative to SQL Connect for working with ODBC-compliant databases and SDE databases. Database Access Version 2.0 can
SDE Database Access--Database Access Version 2.0 also provides more efficient data access for SDE databases. Database Access Version 2.0 supports
Database Access Version 2.0 allows for a dynamic link between the records in a database table and the geographic features in a database theme. This means that a selection made on the theme modifies the selection displayed in the database table. Conversely, a selection made on the database table modifies the selection displayed in the database theme. In addition to selection support, selection-enabled database tables enable the display of all records returned from a query. Database tables are now managed in memory and not cached to disk. This is accomplished by maintaining a subset of records in memory and adjusting the subset as the table is scrolled. Report Writer Extension-Seagate Crystal ReportsArcView GIS 3.2 includes an upgrade from Seagate Crystal Reports Version 6.0 to Version 7.0. Advantages of Version 7.0 include faster reporting and new wizards for advanced reporting. Data Integration UtilitiesThe following new data integration utilities are included with ArcView GIS 3.2: DXF Export--A new data conversion utility providing shape to DXF output is included. SDTS Data Import--ArcView GIS 3.2 includes a new data import utility that imports SDTS raster and point data. Esri GRID files and ArcView GIS point shapefiles are created, respectively. CADReader--The CADReader is compatible with AutoCAD 2000 DWG files (when available). New Sample Utilities and ExtensionsThe following new sample data integration utilities and extensions are included with the sample utilities distributed with ArcView GIS. Digest (ASRP/USRP)--This sample extension provides direct read support for raster data compliant with DIGEST Annex A, a format primarily used by international defense and military agencies. The reader georeferences DIGEST images. There are two profiles: Arc Standard Raster Product (ASRP), produced by the UK Mil Survey, and UTM/Universe Polar Stereographic (UPS) (USRP), produced by the French Defense Mapping Agency. The sample extension supports ASRP 1.1 and 1.2 and USRP 1.2 and 1.3. MGRS Coordinate Display--This sample extension provides interactive display of coordinates on the screen in the Military Grid Reference System (MGRS). MGRS is a coordinate system widely used in defense for designating the location of points of interest. The extension reads source data in decimal degrees, converts the coordinates to MGRS, and displays the MGRS coordinates in a dialog box in real time. The extension converts MGRS coordinates to UTM/UPS and latitude/longitude. As an option, the user can save the UTM/UPS and latitude/longitude coordinates in a separate file. The utility also generates graticules within an MGRS zone for WGS84. S-57 Data Converter--The S-57 data format is defined in the International Hydrographic Organization's Special Publication S-57. This format was formerly referred to as DX-90. S-57 is object-oriented vector data stored in binary format. This sample extension converts the converted binary S-57 (ENC) data to ArcView GIS shapefiles. The extension supports all data types from S-57: spatial objects (connected nodes, isolated nodes, edges, and faces) and feature objects (point, node, line, area, and composite). RPF Indexer--This sample extension uses the geographics extent of each raster product format (RPF) data set and generates a shapefile that can be used as an index theme for RPF image formats. The index theme helps the user choose the images of interest for easier display. The user selects a block or draws a box on the index theme in the View document to display the corresponding images. The user can click on the block (or user-drawn box) again and the images will undraw. Esri Data & MapsUpdated Esri Data & Maps CDs are included with ArcView GIS 3.2. Data updates include
To purchase online visit www.esri.com/gisstore. To order by telephone, call 1-800-447-9778. Or contact your nearest Esri office or your local reseller. |
