Fall 2009 |
New Training Offerings from Esri |
Cost-Effective Training Options for Organizations with Limited Travel BudgetsStaying close to home but still need to learn how to use Esri software more effectively? Consider these training options to keep your GIS skills up-to-date:
Learn more about these options at www.esri.com/taketraining. ArcGIS Data InteroperabilityThe courses below introduce the ArcGIS Data Interoperability extension, which helps GIS and CAD professionals efficiently access, use, and share spatial datasets, regardless of format, structure, data model, and complexity. ArcGIS Data Interoperability Basics—Learn the fundamental concepts of data interoperability and the ArcGIS Data Interoperability extension. Virtual Campus Web Course (Free) Introduction to ArcGIS Data Interoperability Spatial ETL Tools—Receive an introduction to the spatial extraction, transformation, and loading (ETL) tools for data translation and schema mapping. Virtual Campus Web Course Data Transformation with ArcGIS Data Interoperability Spatial ETL Tools—Review the spatial ETL tools and discover how to use transformers inside these tools. Virtual Campus Web Course Advanced Format Translations with ArcGIS Data Interoperability Spatial ETL Tools—Find out how to choose settings and parameters to control data translations. Virtual Campus Web Course Multiple Dataset Translations Using ArcGIS Data Interoperability—Discover how to select multiple datasets and set up translations with multiple formats. Virtual Campus Web Course Custom ArcGIS Data Interoperability Tools and Spatial ETL Best Practices—Explore best practices for spatial extraction, transformation, and loading, as well as how to create and use custom formats and transformers. Virtual Campus Web Course Desktop GISPerforming Analysis with ArcGIS Desktop—Learn a proven process for planning an analysis project and techniques for solving a variety of spatial problems. Instructor-Led Course Creating and Publishing Maps with ArcGIS—Apply a standard cartographic process to ensure your maps are easy to interpret and properly designed for their audience and delivery medium. Instructor-Led Course Server GISAuthoring and Serving ArcGIS Mobile Projects—Learn a recommended workflow for successfully creating and deploying an out-of-the-box ArcGIS Mobile project. Instructor-Led Course Building Web Maps Using the ArcGIS API for JavaScript—Find out how to create Web maps that are attractive, fast, and easy to use by their intended audience. Instructor-Led Course Introduction to Esri MapIt—Discover how to visualize and increase the value of your enterprise data for decision making and planning. Virtual Campus Web Training Seminar (Free) Getting Started with Map Templates—Learn the process of working with map templates to help you make professional-quality maps for print, the Web, and mobile applications. Virtual Campus Web Training Seminar (Free) Implementing ArcGIS Server Geoportal Extension—Learn how to use this solution (formerly GIS Portal Toolkit) to implement local, regional, national, and global spatial data infrastructure portals. Instructor-Led Course Offered by Esri Professional Services For More Information
