ArcNews Online
Fall 2002
Search ArcNews
Water and Wastewater Systems Rise to a New Level in the Shenandoah Valley
Augusta County, Virginia, Manages Water With GIS
By Garnet Daus, Sara Kidd, and Bryan Reid, GeoDecisions
For some people the name Shenandoah brings to mind a legendary American river that is celebrated through song and folklore. For others, the Shenandoah Valley bears witness to numerous Civil War skirmishes and battles. Still others think of the region's Shenandoah National Park and Appalachian Mountains.
In the twenty-first century, Virginia's Shenandoah Valley is a network of thriving, bustling communities with a complex public utilities infrastructure. The Augusta County Service Authority (ACSA), located in central Shenandoah Valley, needed a more comprehensive management and decision tool for its water and wastewater utility systems. No longer adequate for the growing service area, the authority's 1,000-square-mile utility mapping system desperately needed an upgrade.
"We were lucky to have some CAD drawings for a water or wastewater line," says Troy Austin, ACSA project engineer. "Everything was managed by employee memory or paper drawings. It was low reliability as to where the utilities actually were."
To continue to provide effective service for approximately 12,000 customers in this rural area, ACSA decided to implement an advanced GIS to manage its water and wastewater systems.
The Approach
Like many local government agencies, ACSA had been relying on utility drawings, computer-aided design and drafting (CADD), and employee knowledge to manage its systems. Although ACSA had CADD-based water modeling software, the specific information it provided limited its usefulness. To solve this problem, GeoDecisions, a software-independent consulting company and Esri Business Partner, was selected to develop, integrate, and customize a robust data model and design custom applications to meet ACSA's management needs.
"GeoDecisions has extensive experience in setting up GIS throughout the state," says Austin. "They looked at the RFP and tried to figure out exactly what we wanted. They had gone that extra step. Needless to say, we have not been disappointed."
Maintaining network connectivity and data integrity were ACSA's primary goals. Esri's ArcGIS and a geodatabase were selected as the tools to develop the new GIS. The geodatabase design was based on Esri's water and wastewater data model. GeoDecisions worked with ACSA to customize this model to reflect the real-world features in its water and wastewater systems. "We anticipate that GIS will help to keep things maintained and take less time to do it," says Austin.
Data Creation Process
After GeoDecisions completed the geodatabase design, ACSA's existing data layers were updated and new layers were created, using a combination of GPS technology and as-builts (utility drawings). Water meters, pumps, tanks, manholes, and other major point features were captured with GPS and imported into the geodatabase. Scanning and georeferencing ACSA as-builts and other sketches in ArcGIS 8.1 allowed GeoDecisions to place water and wastewater mains in the correct locations. The scanned as-builts were also used to create and verify attribute data of the various features.
Next, ACSA wanted an easy way to retrieve and maintain GIS data, in addition to updating and adding new features. A water/sewer data maintenance application was created by customizing ArcGIS 8 with ArcObjects and Visual Basic for Applications (VBA). This custom application allows users to interactively view and edit the attributes of a chosen feature with standardized entry forms. The application also recognizes the addition of a new feature to the geometric network and automatically displays the attribute interface to the user. When a new feature is created, the application adds it to the geodatabase, sets any default values based on established geodatabase rules, and allows the user to enter any attribute information immediately.
Integration With Billing System
After completing the data conversion process, the focus of the project shifted to integrating the new GIS database with existing nongeographic data management tools. ACSA currently uses a mainframe billing database and server for water meter information. However, to provide a more efficient means for retrieving this information, a custom billing application was developed to incorporate the billing data with the meter data in the geodatabase. This application allows the user to obtain current and past billing information for a chosen water meter, search for meters meeting certain criteria, or select data for calculations and analysis. The application provides powerful graphing functions to allow the user to view billing history data and other information.
Utilizing Existing Analysis Tools
ACSA also wanted the ability to extract new data from the geodatabase for use in its water modeling software. Many organizations and local governments are reluctant to upgrade to an advanced GIS, because they rely on older, established analysis software. These existing software packages often require data in a very specific format. Converting the new data format to match the previous data format can be challenging. This occurred with ACSA's water modeling software, H20NET Analyzer by MWH Soft, Inc., also an Esri Business Partner.
H20NET is an AutoCAD-based water analysis program. Its data format is specific to their application. For example, valves normally represented as points in GIS need to be line segments in H20NET. To correct this, a custom tool was developed to convert existing GIS data to the required data format for H20NET. The export tool was developed in ArcGIS 8 using ArcObjects and VBA. All attribute information was populated and converted to meet H20NET's demands. This resulted in a tool that successfully exports data from the geodatabase into shapefiles, formatted for importing directly into H20NET for analysis.
So far, ArcGIS and the geodatabase have only been implemented in one of ACSA's service areas. Austin expects the system to be in operation countywide within three to four years. "I'm looking forward to it being completed," says Austin. "I think it's going to be a very useful tool for us [ACSA] and the community. From an engineering and customer service standpoint, it's going to greatly improve how we can respond to customer service requests."
In the future, ACSA is considering moving from a personal geodatabase to an ArcSDE solution. ACSA is also looking into the possibility of hosting its GIS online for other ACSA employees and the public to use.
For more information, contact Troy Austin, ACSA project engineer (tel.: 540-245-5670, e-mail: taustin@co.augusta.va.us, Web: www.acsawater.com), or Donald Cole, vice president, GeoDecisions (tel.: 757-873-0768, e-mail: dcole@geodecisions.com, Web: www.geodecisions.com).
