On June 18th we introduced ArcGIS Field Maps and the beta program is now open for enrollment.
![](https://www.esri.com/arcgis-blog/wp-content/uploads/2020/06/FieldMapsMain.png)
Once inside the beta program, the “Getting Started” section will provide you with links to download the Google Play and iOS builds.
In the new user survey you fill out when joining the beta program, we’ll ask you to provide an ArcGIS Online Subscription ID. This is required so that we can unlock access to the ArcGIS Field Maps web app for testing. If you use ArcGIS Enterprise exclusively, you can still join and test the mobile apps. The Getting Started section will walk you through how to register the ArcGIS Field Maps mobile app with your ArcGIS Enterprise portal.
Article Discussion:
