ArcGIS Blog
Mapping
ArcGIS Business Analyst
Updated U.S. geographic boundaries in ArcGIS Business Analyst (June 2024)
By Helen Thompson and S David
With the June 2024 data release, there are boundary changes to several U.S. geography types used in ArcGIS Business Analyst Web App:
  • ZIP Codes are updated with a new source for both 2023 and 2024 boundaries.
  • U.S. Census county boundaries have incorporated Connecticut’s planning regions.
  • CBSAs have been updated to the Office of Management and Budget (OMB) July 2023 delineations.
As a result, saved sites and reports using out-of-date geographic boundaries will not be accessible in the Business Analyst Web App project pane.
Using updated ZIP Codes
U.S. ZIP Code boundaries are available for five-digit ZIP Codes. This year there are more than 50 changes to ZIP Code boundaries, including new boundaries and revisions due to population and delivery route changes. Additionally, the June 2024 Business Analyst release will use TomTom-based ZIP Code boundaries. This will result in changes to the geometry and number of geographies available in the Esri 2023 and Esri 2024 data sources. Consequently, there may be differences in previously saved sites that have used ZIP Codes or are built from a collection of ZIP Codes.
ZIP Code changes impact saved sites
Previously saved ZIP Code-based geographic sites may no longer be aligned with the two demographic vintages and should be updated. Old sites using historic ZIP Code boundaries will not be available in the project pane when using either the Esri 2023 or Esri 2024 data sources. Similarly, previously run reports and exported infographics will show the old boundaries. Where appropriate, we recommend rerunning those reports.
ZIP Code changes impact reports and infographics
There may be differences in infographics, comparison reports, and multi-area reports when comparing the updated ZIP Codes to previous years. This may be due to changes in the geographic boundaries or the underlying data. Where boundaries or data have changed, but the ZIP Code number has not, differences between the current and historic data are expected.
Using planning regions instead of counties in Connecticut
In the June 2024 Business Analyst Web App release, Connecticut administrative boundaries are updated to utilize planning regions instead of counties. Connecticut uses nine planning regions (formerly it used eight counties) to better coordinate constituent services. Planning regions replace counties at the level of geography below state level.
Comparing Connecticut counties to Connecticut planning regions
To learn more about this geography change, see the blog article U.S. Census American Community Survey (ACS) Updated in ArcGIS Living Atlas (December 2023).
Data from Esri 2021, Esri 2022, and Esri 2023 data sources use the old Census boundaries. The forthcoming Esri 2024 data source will use the new planning regions. (The Esri 2021 and Esri 2022 data sources were deprecated in the June 2024 release.)
All Connecticut tracts and block groups within these new planning regions have new census subdivisions (CSDs) and FIPS code whose first five digits reflect the new administrative entities.
Using CBSAs with updated delineations
Core Based Statistical Areas (CBSAs) are composed of central and outlying counties surrounding a population nucleus (such as a city), including related urban areas and adjacent communities. CBSAs are reclassified with a combination of data and census information to reflect how urban areas and the people that live within them are integrated.
A CBSA is either a metropolitan statistical area (MSA) with a population of over 50,000 people in their largest urban area, or a micropolitan statistical area (μSA), with a population of 10,000 to 50,000 people in their largest urban area. For instance, Dallas-Fort Worth, Texas, is an MSA, whereas Seaford, Delaware, is a μSA.
In the June 2024 Business Analyst Web App release, many CBSAs have updated delineations. There are a few reasons why CBSAs change. If the population size decreased, then a CBSA may be demoted from a metropolitan statistical area to a micropolitan statistical area or a non-CBSA. Conversely, if the population size increased, then a CBSA may be promoted from a micropolitan statistical area or a non-CBSA to a metropolitan statistical area. Likewise, the shifting population trends may result in a different allocation of counties to a CBSA.
Twelve CBSAs experienced name changes due to a different principal city being included or dropped.
Map of CBSA changes
To interact with a map visualizing changes to CBSAs, see the web map 2023 Metropolitan and Micropolitan Statistical Areas in the US. This web map was created by the Boyd Center for Business and Economic Research at the University of Tennessee. Note that the map visualizes the difference between the 2024 CBSA delineations and the 2018 delineations. The differences between 2020 and 2018 were minor, therefore the map mostly highlights the more recent changes. The updated CBSA geographic boundaries in ArcGIS Business Analyst Web App is between the 2024 delineation from the 2020 delineation.
Boundary changes impact saved sites and reports
These geography boundary changes impact maps, reports, and analysis.
  • Historic reports that use past geographies may be out-of-date.
  • Analysis areas that are made by aggregating multiple areas (including ZIP Codes, CBSAs, or counties) may be misaligned with current boundaries.
  • Custom datasets may be out of sync with the new release.
The best practice is to update and refresh your reports and custom analytics with each annual release of Business Analyst data, or when boundaries change. To learn more about how changing boundaries can impact your work, check out these blog articles:
Article version history:
  • This article was originally published on May 10, 2024.
  • It was updated on September 11, 2024.
Share this article
Subscribe
Notify of
0 Comments
Oldest
Newest
Inline Feedbacks
View all comments
Terry Brock(@tbrock_montpelier)
April 5, 2020 5:46 pm
Is there a way, or will there be a way at some point, to use our own web maps as the map to guide through?
Jesse Gutierrez(@jesse-gutierrezaustintexas-gov_austin)
April 29, 2020 3:00 pm
Hi Hannah, there’s a blog post from February 2019 about saving URLs and launching from specific points within the guided tour in Classic Story Maps. Will that function be made available in the new Story Maps? I am trying to provide a table of contents of sorts (made from buttons) so users can jump straight to a particular place in the tour. Any suggestions? Thanks.
UPDATE: My colleague pointed out that there is a toggle switch for “navigation” which then creates up to 10 heading based links at the top of the map.
Link to blog post – https://www.esri.com/arcgis-blog/products/story-maps/mapping/launch-a-story-map-tour-at-a-specific-tour-stop/
Maggie Ardito(@maggieardito)
August 7, 2020 9:40 am
How to include an existing story e.g. Guided Tour in a story? I think I get that a story can embed other story types such as Guided Tour and Sidecar… and I see how to start a new one but how do I include an existing one? Thank you for help.
Shawny Ekadis(@queencreekgis)
September 22, 2020 1:56 pm
Hi Hannah, I really like the ability to design my own themes but I just spent two hours setting up a guided tour and manually placing all my locations only to get to item 30 and not be able to add any more locations! Is there really a limit on how many items you can add to a guided tour? If I can’t have more than 30 locations this story map is unusable and unfortunately was a waste of time 🙁
September 22, 2020 2:24 pm
Reply to  Hannah Wilber
That is good news long term, unfortunately we have to have our map up by Oct 1st, so I am back to the drawing board.
