ArcGIS Blog
Constituent Engagement
ArcGIS StoryMaps
Introducing Story Embeds via Script!
By Lee Bock
a stick person stands triumphantly in front of a story web page. on the ground there's a toolbox labeled "javascript" and a paint bucket labeled "css"
Triumph through script embed! (artwork: Warren Davison, Esri)
Check out our companion GitHub repo, which features further documentation and code for all of the examples in this blog post.
Recently, with very little fanfare, the ArcGIS StoryMaps Team released a powerful new feature for developers. This hidden gem is so stealthy, you might not even have noticed it, but it’s a game-changer for the nerds! If you’ve been eager to embed a story directly in a web page, you’ll be excited to learn about the new script embed capability.
But <iframe>…
Wait…Haven’t I always been able to embed a story in my webpage? Isn’t that what <iframe> tags are for? Fair point. The <iframe> tag is a tried-and-true standard for adding external content to your site. It’s ideal for video and other relatively self-contained media, and it may suffice for loading a story into a dedicated space on your page. But in some cases, <iframe> can introduce some frustrating limitations.
The <iframe> element is famously insulated from the rest of the page, making integration between the container and the embedded content tricky.  This isolation can lead to clunky user experiences and developer headaches.
Perhaps the most notorious pitfall of using the <iframe> is the dreaded “double scroll” — that annoying tug-of-war when your story’s vertical scroll sits within your page’s own vertical scroll.  This creates a struggle for scroll supremacy that can make your website feel less polished.
web page with two vertical scroll bars, one right next to the other
The dreaded “double scroll”
Enter Embed via Script
The script embed offers an alternative way to embed a story, freeing you from the limitations of <iframe>. Provided by ArcGIS StoryMaps, this code library links directly into your page and dynamically inserts the story right into your page’s DOM. Once activated, your story and web page content live together in harmony and can interact more seamlessly.
With this setup, you have full access to the story interface through your own CSS and JavaScript. This means more control, easier customization, and a smooth, integrated user experience.
Note: It is important to remember that the story content—including the JSON, resources, and application files—remains hosted in the ArcGIS environment, where you authored the story. As such, your story automatically benefits from any bug fixes, accessibility improvements, and new features we release without your having to redeploy. If you need to manage or edit the story itself, you will continue to do so through the story builder under your ArcGIS StoryMaps account.
Probably better to show rather than tellWhereas this is what a traditional <iframe> looks like…
short snippet of code demonstrating how to insert and into a page
Embed via iframe
THIS is a script embed!
short snippet of code demonstrating how to insert a story embed via script
Embed via script
In case you’re not fluent in gobbledygook, here’s what’s going on in the above lines of code:
  1. The <script> tag points to a script library hosted on the ArcGIS.com server.
  2. Once the page loads, the script is downloaded and invoked.
  3. The script then queries the ArcGIS.com server for the story’s JSON files, which define the content and behavior of the story. Which story? In this example, it’s the story that matches the item ID 1ba69ca9c31b4183b1ee486c36364198.
  4. Next, the script inserts the story application and content into the “storymaps-root” <div> (located just above the <script> tag).
  5. Now, the story is live and running within the HTML structure of your web page!
So, what can I do with this capability?
What can you do with thisFrankly, a lotBecause the story presentation is now woven into your web page, you can write JavaScript code to access and manipulate elements of the storyTheoretically, you could ask for the user’s name and then dynamically insert it at the beginning of each paragraph in the storyBut just because you can doesn’t mean you should, so here’s a short list of practical use case scenarios:
1) Publish a story under the domain name of your choosing.
Screensave of a browser address text field that reads "https://www.your-domain-here/your-story/"
Embedding a story in a container page—whether using script embed or another method—offers one automatic benefit right off the bat: You control the URL where the story appears. Instead of the default storymaps.arcgis.com address, your story is presented at a URL that reflects your own domain. This is especially appealing for organizations that want the story to feel like an integrated part of their website—right alongside their other web resources.
2) Add a branded header and footer to your story.
First panel of the Digging Up Dinosaurs stoy
Look Ma! No double-scroll!
3) Replace the font library with one of your choosing!
Abandoned Islands story page with alternative font
Check out that crazy font!
4) Present a splash page!
web page with a modal splash popup
This is how you make a splash!
Getting started
There are only three prerequisites for using script embeds. You’ll need:
  1. An ArcGIS StoryMaps story to embed (obvi).
  2. A basic understanding of HTML (knowledge of JavaScript and CSS is recommended).
  3. Access to a non-ArcGIS hosting environment. This could be your own server, GitHub Pages, or another third-party hosting service like Netlify or Amazon S3.
Once you’ve met those three conditions, it’s time to do some configuring! First, you’ll configure your story and then your host web page.
Story configuration
To configure your story for embed via script:
  • In edit mode, navigate to the Advanced tab of the Story Settings menu (accessible via the three dots button in the upper right of the builder interface).
  • Toggle Enable advanced embedding to allow your story to be embedded via script.
  • In the Allowed domains section, add the the domain(s) which hosts your page.  Also, if you’re using a development server (e.g. localhost), you’ll want to create an entry for that environment as well.
screenshot of story settings menu's advanced tab
In this example, there's a production domain (e.g. www.example.com) and a development domain (e.g. localhost).
HTML configuration
In your page, you simply need to insert the story embed code, making sure to specify your story’s id as the data-story-id property.  You may recall, the embed snippet looks like this:
Embed via script
If manually typing the embed code seems too daunting (understandable), there’s an easy way to grab the code snippet, pre-configured for your story.  It is available in the builder’s “Embed this story” menu (accessible via the three dots button in the upper right).  In the menu, choose “Script” from the dropdown to reveal the snippet.
Note: The script embed option will only appear once you've: 1) configured the story for script embed, 2) published the story, and 3) shared with Everyone.
A screenshot of a story's embed menu.
Just grab the formatted snippet from here!
Further resources
If you’re seeking additional guidance and inspiration for using embed via script, check out this helpful GitHub repository. It’s public and does not require a GitHub account. The repo includes tutorials covering the three examples mentioned above and more.
github repo webpage
Helpful GitHub repo
And in conclusion…
We’re excited about the new script embed capabilityIt is an effective way to integrate a story into your content, creating professional, interactive experiences. Hopefully it will make your life a little easier, tooHappy embedding!
Share this article
Subscribe
Notify of
3 Comments
Oldest
Newest
Inline Feedbacks
View all comments
