ArcGIS Blog
Mapping
ArcGIS Pro
ArcGIS Pro: Know your options when it comes to Options
By Kory Kramer
When it comes to working effectively in ArcGIS Pro, there are a number of options available to help you set up the application for your work.  And I’m positive that many of you are familiar with this workflow:
Go to the Project tab > click Options > find the tab you’re looking for > make the desired change > click OK > click the back arrow to get back to work.
Workflow demonstrating access to application options through the Project tab.
Hopefully some of you reading this will also be familiar with using the dialog box launchers from the ribbon to access relevant options directly.  So instead of the workflow above, we would access the Selection Options directly from the Selection group on the ribbon.
Use dialog box launchers in ArcGIS Pro to directly access relevant options.
That’s a much more direct route!  Here are a handful of other examples where the dialog box launcher will take you directly to Options:
Navigation Options
Dialog box launcher for navigation options in ArcGIS Pro
Geoprocessing Options
Dialog box launcher for geoprocessing options in ArcGIS Pro.
Editing Options
Dialog box launcher for editing options in ArcGIS Pro.
There are others, so be sure to try out those launchers when you see them!
Today I want to share yet another (um, should I say it?  No, no, don’t do it – look for a synonym.  Ahhh, whatever) option to get to the application options that was introduced in ArcGIS Pro 2.9 last month – Command Search now supports searching for Options.
This means that in addition to the above workflows, you can use Alt+Q (remember Alt+Q?) to search for options.
Use Command Search to find application options.
And even though this is a slight diversion from options, installing offline help is no longer necessary to get search results for help topics in ArcGIS Pro 2.9.  Which makes it easier to do things like find shortcuts to the area of the application you’re working in… because everybody loves shortcuts!
Use Command Search to look up help for shortcuts.
Resources:
Find tools and help using Command Search
ArcGIS Pro keyboard shortcuts
Banner photo by Clem Onojeghuo on Unsplash
Share this article
Subscribe
Notify of
0 Comments
Oldest
Newest
Inline Feedbacks
View all comments
