ArcGIS Blog
Announcements
ArcGIS Pro
What's New in ArcGIS Pro 3.0
By Chelsea Nivison and Javier Angel
As part of the ArcGIS 2022 Q2 release, ArcGIS Pro enables users to expand their GIS abilities with all-new capabilities, performance, and productivity improvements. Catch up on all the new features within ArcGIS Pro through our What’s New in ArcGIS Pro 3.0 video, or please continue reading to discover just a few highlights of this recent update. Before we dive into the highlights, but sure to review the best practices for both migration and working between ArcGIS Pro 2.x and 3.0, feel free to click the link here for the latest.
Migration from ArcGIS Pro 2.x to 3.0
After reviewing the new system requirements and installing ArcGIS Pro 3.0, projects and files that you or others created in ArcGIS Pro 2.9 or earlier can be opened because they are forward compatible. When you save them using ArcGIS Pro 3.0, they are enabled with properties that allow you to take advantage of new capabilities.
Backward compatibility
Because ArcGIS Pro 3.0 is a major release, the files it saves may or may not work with the ArcGIS Pro 2.x series. Details of what works and what doesn’t are provided later in this topic. However, you don’t need to worry about those details if the projects and documents you create or save are always used in ArcGIS Pro 3.x. This is the case when the following occurs:
  • You don’t share your ArcGIS Pro files with other ArcGIS Pro users, such as if you are the only GIS analyst in an organization.
  • You and your colleagues, between whom you share ArcGIS Pro files, upgrade to ArcGIS Pro 3.0 at the same time.
Considering that collaboration is simplified when colleagues are on the same major version, organizations may plan to simultaneously migrate all of their instances of ArcGIS Pro 2.x to 3.0.
Highlights
Now that you’re caught up to speed and ready to run the latest release of ArcGIS Pro, here are some of our favorite features that we are excited to bring you.
Package Manager
The Package Manager page allows you to manage conda environments for use within ArcGIS Pro. Formerly identified as the Python page, the Package Manager page now supports the upgrade of conda environments you’ve created in previous versions of ArcGIS Pro to the current version, the repair of broken environments, and the renaming of existing environments.
In addition, the Package Manager is more responsive, with a new task queue to keep track of the status of your environment and package changes, and detailed conda messages are provided for all operations.
ArcGIS Pro package manager
Add maps to reports
You can now add a map to a report. Maps that you add to the report header or footer are static. You can activate the map frame to adjust the map extent or scale. Maps that you add to a group header, group footer, or details subsection are dynamic. In the report view, the map frame of a dynamic map cannot be activated; however, the exported result updates in scale and extent to reflect the feature or features included in that subsection.
ArcGIS Pro add a map to a report
ArcGIS Knowledge
If you have configured an ArcGIS Enterprise 11.0 Knowledge Server appropriately, you can create a new investigation and knowledge graph using a Neo4j database as a NoSQL data store.
A new Geographic layout is available for link charts. Entities in the link chart are positioned on a map using their spatial geometry. Spatial data can also be added to the link chart and a basemap can be used to provide context for the knowledge graph’s spatial entities.
For more new functionality and updated licensing information, see ArcGIS Knowledge in the Data management and workflows section.
ArcGIS Knowledge
Export presets
You can create export presets for maps and layouts in ArcGIS Pro. Export presets save all the settings for a particular export type. When you export a map or layout, you can select a default preset or a custom preset you created. This allows for a faster and more consistent export experience.
Presets are available in the export gallery on the Share tab of the ribbon. You can also browse to preset files (.xprt) on the file system. Presets can be created for any export type.
Export presents in ArcGIS Pro
Hungry for more? Catch up on all the new features within ArcGIS Pro 3.0 through the recent What’s New in ArcGIS Pro 3.0 video today.
Not Yet An ArcGIS Pro User?
That’s fine, feel free to try ArcGIS Pro for yourself through our ArcGIS Pro Trial below.
Free ArcGIS Pro Trial
Share this article
Subscribe
Notify of
4 Comments
Oldest
Newest
Inline Feedbacks
View all comments
Hans-Jørg Schneidt(@hjschneidt)
July 11, 2022 2:51 am
Hi,I´m astonished that you removed the ability to automatically convert CAD drawings to geodatabase in Pro 3.0. Please reinstall this feature at the next update.
anna garrett(@agarrett528)
July 14, 2022 9:01 am
please post a write up of all the changes in 3.0. not everyone has time to sit through a video and wait patiently for features that are relevant to them to show up, if they do. this is really disrespectful of our time as users.
Kate Hess(@khess)
January 13, 2023 8:22 am
Reply to  anna garrett
Hi Anna – the written version is located here.
Nick Jones(@njones_dewberry)
September 8, 2022 8:50 am
I’ve noticed a number of tools have added parameters, and it has been a bit challenging with python scripts. Is there a list of all the tools with changed parameters? I know Delete Field, Join Field, and Zonal Statistics as Table, for example, have changed. If you develop a script in 3.0 and then somebody with an earlier version uses it, you have to be aware of these things.
