ArcGIS Blog
Announcements
ArcGIS Pro
PerfTools (Build 280) for ArcGIS Pro 2.x and 3.x is now available for download
By Ian Sims
The Performance Engineering team is pleased to announce the availability of the new PerfTools Add-in for ArcGIS Pro, version 2.x and 3.x. This is a new release (Build 280) of a widely-used tool for assessing performance of ArcGIS Pro and its underlying spatial data in your organization.
Are you curious to know how long ArcGIS Pro takes to execute a GP tool with various different parameters, edit a feature class, render a particular bookmark or spatial extent, or play an animation? Or have you needed to monitor how long it takes to make a spatial selection from your underlying data? These are some questions that PerfTools allows you to investigate.
With PerfTools, a comprehensive scripting capability allows you to edit, run, and log performance scenarios as you make underlying changes to your hardware, virtualization environments, spatial data, or other key user workflows. You’ll soon be able to discover any performance ramifications, make adjustments, and re-run. To get you started, we’ve enclosed several sample scripts with the PerfTools download.
PerfTools Build 280 contains several usability and stability improvements. The custom script command tutorial has been thoroughly revised with documentation updates. The “ExecuteTool” script command previously only output execute time errors; now this outputs execute time warnings in addition. Additionally, PerfTools can now handle Stereo Map and Scene layers that do have any visible layers.
A complete list of new functionality available is contained within the “WHAT’S NEW.txt” that accompanies the Add-in in the download.
Note: There are now three versions of PerfTools contained within the download:
  1. for Pro 2.7.x – 2.9.x
  2. for Pro 3.0.x – 3.2.x
  3. for Pro 3.3.x and newer
Please select the version appropriate for your installation by selecting the applicable folder within the download ZIP archive.
After installing the add-in and opening Pro, Take a look in your Documents\ArcGIS\AddIns\ArcGISPro\PerfTools folder. You should see a PDF there titled PerfTools_for_ArcGIS_Pro.pdf. This contains comprehensive documentation and sample code snippets.
Download PerfTools (Build 280) for ArcGIS Pro 2.x and 3.x
Non-English locales should enable English (US) regional settings for correct execution.
Disclaimer: This add-in is not supported by Esri Support Services; any questions or feedback regarding PerfTools should be forwarded to perfqatools@esri.com
Share this article
