Deep learning works exceedingly well with satellite and aerial imagery, but did you know that it can let you look underwater as well? At the UC 2020 plenary, Shannon Kalisky showed a demo of detecting shipwrecks from bathymetric data. This blog post shows how this was done using the deep learning tools in ArcGIS.
Looking at NOAA’s electronic navigational S-57 charts in the area of Jamaica Bay in NY, we see that there are 2 shipwrecks identified. Wreckage like this can lead to navigational hazards:
Unfortunately, this area was among the many across the eastern seaboard, that was devastated by Hurricane Sandy in 2012. Survey data post hurricane Sandy from NOAA shows a number of shipwrecks that are not updated in the S-57 chart above:
We needed to update the electronic navigational chart for Jamaica Bay, NY – an area spanning over 100 sq. km. Doing this manually would have been a daunting task.
Here’s where deep learning came to our resue. We used deep learning based Object Detection models to automate the task of detecting shipwrecks. Here’s the process that we followed:
1. Preprocess bathymetric data
The input data that we used was in Bathymetric Attributed Grid (BAG) format. BAG data is two-band imagery where one of the bands is elevation and the other is uncertainty in the elevation values. We applied the shaded relief function in ArcGIS, which is also used by NOAA in one of their BAG visualizations here. Shaded Relief is a 3D representation of the terrain which differentiates shipwrecks from the background and reveals them in an easily interpretable manner as compared to the raw bathymetric data.
2. Capture training samples
All supervised deep learning tasks depend on labeled datasets, which means humans must apply their intelligence to train the neural network on what it is trying to identify. The labeled objects are used by the neural network to learn what it is expected to detect. While you can use regular editing tools for the task, ArcGIS Pro now includes a labelling tool specifically designed for deep learning workflows.
With the Label Objects for Deep Learning tool, we can dive right in and start capturing training samples:
3. Export training samples
The deep learning toolset within the Image Analyst toolbox in ArcGIS Pro gives you access to all deep learning tools. This toolset contains tools for the complete deep learning workflow – from exporting training data, to training deep learning models and finally for using trained models to detect specific features in an image or to classify pixels in a raster dataset.
The Export Training Data for Deep Learning tool created the image chips which were used to train the deep learning model.
The output of this tool was a bunch of training chips and metadata:
4. Train the deep learning model
We can train the shipwreck detection model using the Train Deep Learning Model tool in ArcGIS Pro or using the arcgis.learn module in ArcGIS API for Python. A sample notebook which showcases the workflow using arcgis.learn is here.
The Train Deep Learning Model tool greatly simplifies the process for GIS analysts. All you need to do is point at the folder of the training data that was exported in the previous step and give the location where the trained model will be saved.
The tool is very easy to use, and has intelligent defaults, while also allowing you the flexibility to customize the training process using advanced settings.
The Max Epochs parameter defines the number of times the dataset will go through the neural network – essentially the number of cycles or training passes over the training samples. This is really dependent on the model you’re training, distribution of features, complexity of the scene and the amount of training samples that you have. If you have a lot of training samples, you can keep this number low. We generally keep training the model over several epochs repeatedly, till the validation loss (or the error rate) keeps reducing. However, there is an option where the model training will stop when the model is no longer improving, regardless of the Max Epochs parameter value specified.
The output is a trained model in the form of a Deep Learning package, containing an Esri Model Definition (EMD file), that can then be used for detecting shipwrecks across the entire area of interest.
5. Use the model
We used the Detect Objects Using Deep Learning tool to detect shipwrecks across our area of interest. We specified the input raster and the location to the trained model (EMD file) and the detected shipwrecks were created in the Output Detected Objects feature class:
Finally, we used the results to update the S57 navigational chart, where you can also compare the results with the previous chart:
See these resources for information on deep learning using ArcGIS:
- Deep learning in ArcGIS Pro
- Geospatial deep learning with arcgis.learn
- Deep learning models in arcgis.learn
Special thanks to Guneet Mutreja and Sandeep Kumar for their contributions.
Article Discussion:
