In the news: As much of the U.S. endures record setting heat, ocean temperatures in some areas off the Florida Coast have surpassed 100 degrees Fahrenheit, making the ocean seem more like a hot tub. Coral is highly sensitive to temperature, and while temperatures in the mid-80s can be the norm, the latest surge in temperature causes coral to “bleach,” expelling symbiotic algae and turning white. While bleaching doesn’t necessarily kill coral, it does mean they are stressed and subject to increased mortality especially as warmer than normal temperatures persist. For more information, see NOAA’s What is coral bleaching?
![NOAA coral bleaching infographic NOAA coral bleaching infographic](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/08/stcb-1s.png)
Make a sea surface temperature and coral bleaching map
ArcGIS Living Atlas of the World includes authoritative content that helps you learn more about current sea temperature and coral bleaching. Follow these steps to make your own sea surface temperature and coral bleaching map in a minute, maybe less.
Step 1 — Sign in to your ArcGIS account and open Map Viewer. There are two ways to add layers from the Content (dark) toolbar:
(1) Click Add, then Browse layers.
![Browse layers Browse layers](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/06/add-browse-layers.png)
or (2) Click Layers, then Add.
![Add layers Add layers](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/06/add-layers.png)
Step 2 — Choose Living Atlas from the Add layer drop-down.
![Add layer from Living Atlas Add layer from Living Atlas](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/06/add-layer-law.png)
Step 3 — Enter “sea temperature” in search to locate matching layers from Living Atlas. Locate the HYCOM – Sea Water Temperature layer and click [+ Add] to add it to the map.
![Add Living Atlas layer Add Living Atlas layer](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/08/stcb-4.png)
Tip: To learn more about any layer, click the layer card to view the item information, such as overview, description, and more. Click View item at the bottom to open the full item pages.
![Layer information Layer information](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/08/stcb-5.png)
From the HYCOM – Sea Water Temperature item details, we learn that the layer shows a 7-day forecast and 30-day hindcast from the HYbrid Coordinate Ocean Model (HYCOM). The multidimensional imagery layer provides information on a variety of variables, including temperature, temperature at specific depths, and more.
After adding the layer, a time slider will appear showing the time range encompassing the 30-day hindcast to the the 7-day forecast. Click the layer to view the pop-up. By default the layer displays the information recorded for 30 days ago (the hindcast) and the temperature at the surface.
![HYCOM Sea Water Temperature pop-up HYCOM Sea Water Temperature pop-up](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/08/stcb-6.png)
Next, we’ll adjust the HYCOM layer settings to show the temperature for the current date, and since temperature at the surface is typically warmer than below, we’ll adjust the depth to show the temperature about 10 to 15 feet below the surface.
Step 4 — Open the Multidimensional tool from the Settings (light) toolbar.
![Multidimensional tool Multidimensional tool](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/08/stcb-7.png)
The pane shows the display slice variables, including (a) a time dimension slider and (b) the Z dimension slider, which in this case is depth below surface.
![Multidimensional sliders Multidimensional sliders](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/08/stcb-9s.png)
Step 5 — Adjust the the time slider by using the left/right arrows, or grab and move the time slider control, to set the current date and time.
![Time slider control Time slider control](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/08/stcb-10.png)
Step 6 — Adjust the the Z dimension (depth below surface) slider using the up/down arrows or use the slider control to set it to -4m, roughly 10 to 15 feet below the ocean surface where coral may be growing.
![Z dimension slider Z dimension slider](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/08/stcb-11.png)
Click Done when finished. You can verify the settings you have made by opening the pop-up to show the temperature at the specified depth and current date.
In the next steps, we’ll add the coral bleaching layer.
Step 7 — Add another layer from Living Atlas (see Steps 1 and 2 above) and enter “coral” in search to locate matching layers from Living Atlas. Locate the NOAA Coral Reef Watch (CRW) Virtual Stations layer and click [+ Add] to add it to the map.
![Add layer from Living Atlas Add layer from Living Atlas](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/08/stcb-12.png)
To learn more about the layer, click the layer card to view the item information, such as overview, description, and more. Click View item at the bottom to open the full item pages.
![Layer information Layer information](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/08/stcb-13.png)
From the NOAA Coral Reef Watch (CRW) item details, we learn that the layer shows current coral bleaching conditions around the world with daily updates.
After adding the layer to the map, click to view the pop-up information.
![Coral bleaching alert pop-up Coral bleaching alert pop-up](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/08/stcb-14.png)
The sea temperature and coral bleaching map
Technically, in just about a minute, we’ve created a map showing current temperatures beneath the ocean surface along with current coral bleaching alerts. The layer pop-ups deliver information about current sea temperature and coral bleaching alerts.
![Sea temperature and coral bleaching map Sea temperature and coral bleaching map](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/08/stcb-17s.png)
Improve the map
With a few additional steps, the map can be improved using styles, effects, and additional layers to make it more expressive.
Experiment with different basemaps to see which you like best. You can alter layer transparency and symbols to emphasize the content you want, and use Effects to emphasize layers or alter their display.
The map shown below was created using the following:
- Basemap derived from the prototype Physical Geography Basemap, using layer visibility modifications and effects.
- Added transparency for sea water temperature layer.
- Changed symbols and added transparency and effects for coral reef watch stations and areas.
![Modified web map Modified web map](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/08/stcb-19s.png)
More information
For more information, see the following:
