In the news: Mandatory and voluntary evacuations have been issued for eight counties along Florida’s Gulf Coast as Tropical Storm Idalia intensifies over warm water, expecting to reach landfall as a Category 3 hurricane. Idalia is forecast to bring heavy rainfall and flooding, damaging winds, and life-threatening storm surges with inundation potentially reaching over ten feet in some areas.
![NOAA weather outlook NOAA weather outlook](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/09/h-21s.png)
Make a hurricane map
ArcGIS Living Atlas of the World includes authoritative live feeds and other content that helps you learn more about active hurricanes, cyclones, and typhoons. Besides making your own map in under a minute using ArcGIS Online and ArcGIS Living Atlas content, you can use other applications that use the same live feeds to visualize and learn more about hurricanes.
Follow these steps to make your own hurricane map in a minute, maybe less. This tutorial will cover the following:
- Make an ArcGIS Online map using the ArcGIS Living Atlas Active Hurricanes live feed.
- Refine and finalize the map by changing the basemap and adjusting layers and styles (optional).
You can also try ready-to-use apps like Hurricane Aware and Hurricane Public Information Map.
Step 1 — Sign in to your ArcGIS account and open Map Viewer. There are two ways to add layers from the Content (dark) toolbar:
(1) Click Add, then Browse layers.
![Browse layers Browse layers](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/06/add-browse-layers.png)
or (2) Click Layers, then Add.
![Add layers Add layers](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/06/add-layers.png)
Step 2 — Choose Living Atlas from the Add layer drop-down.
![Add layer from Living Atlas Add layer from Living Atlas](https://www.esri.com/arcgis-blog/wp-content/uploads/2023/06/add-layer-law.png)
Step 3 — Enter “hurricane” in search to locate matching layers from Living Atlas. Locate the Active Hurricanes, Cyclones and Typhoons layer and click [+ Add] to add it to the map.
![Living Atlas search Living Atlas search](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/09/h-22.png)
Tip: To learn more about any layer, click the layer card to view the item information, such as overview, description, and more. Click View item at the bottom to open the full item pages.
![Layer information Layer information](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/09/h-23.png)
From the Active Hurricanes item details you will learn that the layer shows the observed path, forecast track, and intensity of tropical cyclone activity (hurricanes, typhoons, cyclones) from the National Hurricane Center (NHC) and Joint Typhoon Warning Center (JTWC). The source is checked for updates every 15 minutes using the aggregated live feed methodology.
Step 4 — Click the left arrow to return to the Layers pane in the Contents (dark) toolbar.
![Return to layers pane Return to layers pane](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/09/h-24.png)
Step 5 — Expand the Active Hurricanes, Cyclones, and Typhoons layer to view its sublayers.
![Expand Expand](https://www.esri.com/arcgis-blog/wp-content/uploads/2021/08/h-3.png)
Hide or show sublayers to display the information you want. Explore the map and click features to learn more. The map was created in less than a minute, but additional refinements can be made to customize the map to suit your tastes and needs. Use the Layer pane to toggle or select sublayers, use the Settings (light) toolbar to change layer style and other settings.
In the example below, several layers were toggled to show the current track, the forecast cone, and the predicted hurricane force winds with partial transparency. In addition, the basemap was changed to Firefly Imagery Hybrid.
![Hurricane map Hurricane map](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/09/h-25s.png)
Use Hurricane Aware
Hurricane Aware is a ready-to-use Living Atlas application that uses the same live feeds layer as above. The app also adds demographic information to help you learn more about impacted areas. Follow these steps to use Hurricane Aware.
Step 1 — Go to the ArcGIS Living Atlas website Apps tab and look for Hurricane Aware.
Step 2 — Open Hurricane Aware by clicking the thumbnail to View app details.
![View app details View app details](https://www.esri.com/arcgis-blog/wp-content/uploads/2020/08/hur-8.jpg)
Step 3 — Click View application.
![View application View application](https://www.esri.com/arcgis-blog/wp-content/uploads/2021/08/h-5.jpg)
Step 4 — Click Select Storm and choose from the current active storms. Idalia was selected, at this moment a tropical storm but forecast to become reach hurricane strength as it heads to Florida.
![Select storm Select storm](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/09/h-26.png)
Step 5 — View the selected storm. The forecasted storm intensity is displayed on the right, click an entry to zoom to the forecasted event.
![Storm forecast Storm forecast](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/09/h-27s.png)
Step 6 — Click anywhere within the United States to learn more about local weather and community demographics. A yellow dot appears where you click.
![Get demographic information Get demographic information](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/09/h-28.png)
Scroll down in the side panel to see additional charts. The data shown is from Living Atlas using authoritative U.S. government sources. These include live feed National Weather Service forecasts for hurricanes, precipitation, and wind gusts. Demographic information is from the U.S. Census American Community Survey (ACS).
![Weather and demographic information Weather and demographic information](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/09/h-29.jpg)
The Hurricane Public Information Map is built and maintained by the Esri Disaster Response Program. It uses ArcGIS Experience Builder, ArcGIS Living Atlas live feeds and basemaps, along with the Public Information solution template. To use the app, follow these steps.
Step 1 — Locate the app on the Esri Disaster Response Program website. Open the Disasters tab, then choose Hurricanes.
![Disasters tab - Hurricanes Disasters tab - Hurricanes](https://www.esri.com/arcgis-blog/wp-content/uploads/2020/08/hur-24.jpg)
Step 2 — From the Hurricanes page click View map in full screen to open the app.
![Open Hurricane Public Information Map Open Hurricane Public Information Map](https://www.esri.com/arcgis-blog/wp-content/uploads/2021/08/h-10.png)
Step 3 — Explore the map using the available tools and tabs. The Layers tab in the upper right enables you to show or hide layers. Experiment to create the desired map by hiding or showing different layers or changing the basemap. Click any feature to learn more about it.
![Hurricane information Hurricane information](https://www.esri.com/arcgis-blog/wp-content/uploads/2022/09/h-30.png)
More information
You can make a hurricane map using authoritative live feed sources in well under a minute using any of the options discussed above. For more information, see:
- Browse Living Atlas layers
- ArcGIS Living Atlas
- ArcGIS Living Atlas Apps
- Esri Disaster Response Program
- Esri Disaster Response Program Hurricanes
This blog article was originally published on August 24, 2020, and has been updated.
