By Florian Brandi-Dohrn, AED-SICAD
Connecting renewables to the grid is a complex workflow and process for utilities. For instance, where does one place outlets for electric cars without endangering grid stability and energy provision security? Or, for a new residential area, how does one plan the new lines and connect them to the grid intelligently? These manual processes deserve a better way, especially in an era of continuous digitalization of our core processes. Thankfully, we developed the UT Smart Apps to solve just this challenge.
Some of the leading DSOs are using the UT Smart Apps. These JavaScript-based web clients running in the Esri Portal come in three modular flavors:
PLAN
The PLAN module allows you to create planning projects and scenarios. Design as many scenarios as you like and draw the grid for each scenario as you like. Add the load, or the generated energy at each end point, and use the CAD-like construction tools to be sure that each point is at the right location.
CALC
Second, the CALC module allows you to start a network calculation (e.g., a load flow) with one simple click. Most importantly, this network calculation runs directly on your precious, low-voltage GIS data. . Using the CALC module, you can simulate various planning scenarios. In addition, you can simulate switching scenarios in case you’d like to re-configure the grid due to new, planned assets.
EDIT
Finally, the EDIT module allows you to update the switch status. The correct switch status is an important aspect in the use of these Smart Apps, because the correct topology is a very important piece of information for the network calculation. For ease of use, many users have combined all this functionality into one convenient web app.
Why Use UT Smart Apps?
Those DSOs working with the UT Smart Apps cut down in the technical evaluation of new service points, new renewable plants, or simply electric outlets for cars. Some current users report getting 95% of their technical evaluations down from 15 hours to just 30 minutes. And of course, all technical evaluations are now properly documented, allowing for each decision to be backed up with a proper document detailing the load flow calculation that was run.
The UT Smart Apps save utilities millions of dollars per year, thanks to their dramatic reductions in time spent manually calculating the impact of grid connections. On average, the apps help planning engineers shave 15 hours off the assessment of new grid connections, especially for renewable sources.
AED-SICAD is partnering with Esri Platinum Partner SSP Innovations to implement the UT Smart Apps at U.S. utilities. Find AED-SICAD and SSP in the exhibitor hall at the 2017 Esri User Conference in San Diego, booths 927 and 926. Don’t hesitate to ask either of them about the UT Smart Apps in person.
